JasonXXX's avatar
JasonXXX
readynas and CRT TV
Hi, I want to playback the movies on my CRT Tv from readynas. is there any way to do so? do i have to do it through a tivo box? please help out. appreciate much
  • StephenB's avatar
    Usually you would need a media player (for instance WD Live or a Netgear NTV550).
    thanks for your kindness and help!
  • StephenB's avatar
    You're welcome. Note that media players vary in what they can play, So (like NAS) you do need to do some research before you buy.
  • Xtreamer for me, if it's media players your after. I've got the mk.I XT and it's flawless with my two ReadyNAS (1 Sparc & 1 x86) units, amongst other stuff.
  • thank you guys for the replies!
    sorry,im not very good with stuff like this.
    after having done some researches,it seems out of those media players, the WD live is more affordable comparing to others
    i dont think is necessary to buy the costly ones like xtreamer? i just checked its so expensive!
    all i want is to play the movies from the HDD's i stored in my readynas ultra.
    does the WD live include the 4 x RCA Phono Red White Yellow Black Lead Cable so that i can use them on my CTR TV?
    thanks again
    regards
    No idea how much the WD is, or it's quality and features, but the basic XT (Sidewinder or Elvira) is the bottom end of the range, (?) and still way above most more expensive units. In the UK, it works out about £99 delivered. IIRC, though not checked recently, I haven't needed to!) The community support and community features are another definite plus in it's favour.
  • StephenB's avatar
    thanks again
    regards
    There are several models, you should check the install guides at wdc.com
    Though generally, composite video uses 3 RCA phono (yellow for video, the other two for stereo audio). Component uses 5 RCA phono (three for video, 2 for stereo audio).
    Not sure about 4 x RCA. Are you sure that all 4 are RCA? Generally I'd expect one to be S-video.
ProSupport for Business
