MountainMak
Jun 19, 2020Aspirant
ReadyNAS Can't Connect to ReadyCloud- RN102
Hi Community. I have been using my RN102 successfully as a backup for google drive and local archive/local access (still works fine). I wanted to turn on readycloud access to start using remote ...
- Jul 10, 2020
Just a follow up to let everyone know the progress..
I worked with John on a few attempts to fix including reinstalling the os ... none of them worked.
I finally did the long fix by backing everything up on an old NAS collecting dust in the closet where support ended (Iomega Storcenter x2)... then doing a full factory reset.
that fixed the problem. NAS is now functioning as expected. Not sure what the root cause was but guessing some corruption in some file... just not worth the time to dig into.
Now just restoring ...
Thanks for all the support everyone.
Cheers
JohnCM_S
Jun 19, 2020NETGEAR Employee Retired
Hi MountainMak,
Welcome to the Community!
Can you download the ReadyNAS system logs then provide it to us. We will try to check what the issue is. You can upload the logs to a file-sharing site then send me the download link via private message.
