MountainMak
Jun 19, 2020Aspirant
ReadyNAS Can't Connect to ReadyCloud- RN102
Hi Community. I have been using my RN102 successfully as a backup for google drive and local archive/local access (still works fine). I wanted to turn on readycloud access to start using remote ...
- Jul 10, 2020
Just a follow up to let everyone know the progress..
I worked with John on a few attempts to fix including reinstalling the os ... none of them worked.
I finally did the long fix by backing everything up on an old NAS collecting dust in the closet where support ended (Iomega Storcenter x2)... then doing a full factory reset.
that fixed the problem. NAS is now functioning as expected. Not sure what the root cause was but guessing some corruption in some file... just not worth the time to dig into.
Now just restoring ...
Thanks for all the support everyone.
Cheers
JohnCM_S
Jun 19, 2020NETGEAR Employee Retired
Hi MountainMak,
Welcome to the Community!
Can you download the ReadyNAS system logs then provide it to us. We will try to check what the issue is. You can upload the logs to a file-sharing site then send me the download link via private message.
Sandshark
Jun 20, 2020Sensei
You should not assume that a similar symptom always has the same solution. There are many reasons that your NAS might not see the ReadyCloud server.
Does your NAS see the ReadyNAS OS updates available? If not, then the cause of your problem is likley in your IP configuration, especially if you have set a static IP address.
- StephenBJun 20, 2020Guru - Experienced User
Start by looking for the two green checkmarks on the cloud page of the web ui.
- MountainMakJun 22, 2020Aspirant
Yes I can see updates, system can check and tell me it is at the latest version. 6.10.3
I looked at my logs and saw the users getting deleted in march 2017 as per the the criteria listed. I was not assuming ... just guessing (and hoping there would be more transparancy of the root cause) :)
No static ip configured, the NAS is wired into my orbi RBK50 configured for AP mode that is connected to my ATT/FTTH Gateway/router.
I also have the google drive app installed on my NAS and it works fine... just readycloud seems to be the issue.
I see one green checkmark (internet available)...
I will grab the logset and pass on to JohnCM_S
Thanks for all the good questions... I beleive I investigated all those options already ...
Cheers
- StephenBJun 23, 2020Guru - Experienced User
There are quite a few posts here on the 2017 issue. Netgear did take responsibility, so I don't understand your transparency comment.
In any event, the issue at hand is getting ReadyCloud to work for you in 2020. Hopefully JohnCM_S will be able to help with that.
There are alternatives to ReadyCloud btw - you could for instance switch to OwnCloud.or NextCloud.
- MountainMakJul 10, 2020Aspirant
Cheers
