MountainMak
Jun 19, 2020Aspirant
ReadyNAS Can't Connect to ReadyCloud- RN102
Hi Community. I have been using my RN102 successfully as a backup for google drive and local archive/local access (still works fine). I wanted to turn on readycloud access to start using remote ...
- Jul 10, 2020
Just a follow up to let everyone know the progress..
I worked with John on a few attempts to fix including reinstalling the os ... none of them worked.
I finally did the long fix by backing everything up on an old NAS collecting dust in the closet where support ended (Iomega Storcenter x2)... then doing a full factory reset.
that fixed the problem. NAS is now functioning as expected. Not sure what the root cause was but guessing some corruption in some file... just not worth the time to dig into.
Now just restoring ...
Thanks for all the support everyone.
Cheers
Sandshark
Jun 20, 2020Sensei
You should not assume that a similar symptom always has the same solution. There are many reasons that your NAS might not see the ReadyCloud server.
Does your NAS see the ReadyNAS OS updates available? If not, then the cause of your problem is likley in your IP configuration, especially if you have set a static IP address.
Jun 20, 2020Guru - Experienced User
Start by looking for the two green checkmarks on the cloud page of the web ui.
