MountainMak
Jun 19, 2020Aspirant
ReadyNAS Can't Connect to ReadyCloud- RN102
Hi Community. I have been using my RN102 successfully as a backup for google drive and local archive/local access (still works fine). I wanted to turn on readycloud access to start using remote ...
- Jul 10, 2020
Just a follow up to let everyone know the progress..
I worked with John on a few attempts to fix including reinstalling the os ... none of them worked.
I finally did the long fix by backing everything up on an old NAS collecting dust in the closet where support ended (Iomega Storcenter x2)... then doing a full factory reset.
that fixed the problem. NAS is now functioning as expected. Not sure what the root cause was but guessing some corruption in some file... just not worth the time to dig into.
Now just restoring ...
Thanks for all the support everyone.
Cheers
Jun 23, 2020Guru - Experienced User
MountainMak wrote:
I looked at my logs and saw the users getting deleted in march 2017 as per the the criteria listed. I was not assuming ... just guessing (and hoping there would be more transparancy of the root cause) :)
There are quite a few posts here on the 2017 issue. Netgear did take responsibility, so I don't understand your transparency comment.
In any event, the issue at hand is getting ReadyCloud to work for you in 2020. Hopefully JohnCM_S will be able to help with that.
There are alternatives to ReadyCloud btw - you could for instance switch to OwnCloud.or NextCloud.
MountainMak
Jul 10, 2020Aspirant
Cheers
