dekkit
Nov 10, 2009Aspirant
ReadyNAS Data Recovery - VMware recovery tool
Description
This topic contains links to linux VMware images (Debian / Ubuntu) that have been modified to enable you to access your ReadyNAS duo HDDs from any machine with a USB plug and a SATA to USB cable.
Advantages:
* VMware player be downloaded freely
* Can run in both existing linux / MS Windows (XP,Vista etc) operating system without any further modification
Disadvantages:
* Requires a SATA to USB cable
* Mac users will need to find another program to run the VMware files
Background
At some point your ReadyNAS Duo unit is going to stop working (which hopefully will be long and far into in the future) and there may be a point where you'll need to rely on your external backups.
While it's a good strategy to ensure you (and your family / clients) have a good disaster recovery process (having external off-site backups, checking the backups, knowing how to restore from backups etc), in some cases the backups might not work or the backups aren't available to you.
Due to the architecture of the ReadyNAS Duo (more specifically the 16KB blocksize of the partitions), you cannot simply pull out the hard disks, place them into a standard windows / linux pc, then copy all your files across to another computer or storage device.
Unfortunately there are no windows drivers that can properly access the drives and the process to configure a linux pc is complex (see viewtopic.php?f=25&t=24861&hilit=16+blocksize for further background on this)
The following VMware images contain all required patches to read your HDDs in linux just by entering a few terminal commands.
VMplayer Link
To get started, you will need to download a version of VMplayer for your operating system Win/Linux (Mac not directly supported yet), this can be found
http://www.vmware.com/products/player/
VMware Linux Image with Ext2Fuse
acmtn Debian release - tested ok, reports are that it works fine except for files greater than 4GB)
http://www.readynas.com/contributed/dek ... ebian5.zip
acmtn VM login info (username/password): root/rootadmin, vmuser/vmuser1
(please read the forums for more details on how to use this vmware )
_vito Ubuntu release - currently being tested, enables you to use the HDDs directly plugged into your pc without the need for a SATA to usb cable.
http://www.readynas.com/contributed/dek ... buntu9.rar
Details on this alternative vmware can be found on this post (you'll need to review the instructions carefully):
viewtopic.php?p=203653#p203653
dekkit Debian release - tested, a number of issues.
my initial attempt that helped start this thread has been found to have quite a few issues and may not work for you, but can be found here if you would like to try:
http://www.readynas.com/contributed/dekkit/VMwareDebian5.0%20-%20ext2Fuse.rar
dekkit VM login info: User: vmplanet pass: vmplanet.net
the acmtn version at this stage appears to be getting more reliable results for users. Unfortunately, I have not had time improve on my original dekkit release due to time constraints but if you would like to try please post your results.
Dekkit release Notes:
* You will need 8GB of free disk space once you have uncompressed the image
* You will still need to execute some of the terminal commands to mount the drive (take precaution so you don't accidently blow away your data)
* This VMware can access other windows file shares and can also be configured to host windows shares (see the docs for debian for more info on this)
* To uncompress the file use WinRar: http://download.cnet.com/WinRAR-32-bit/ ... 07677.html or for non-windows platforms try: http://www.rarlab.com/download.htm
* This image is a work in progress (WIP) so please post all errrors !!!!!.
Dekkit release Usage- this may apply to the other versions (eg acmtn
Login to the OS
Access the terminal and enter the following once the HDD has been attached (take note that your /dev/c may differ):
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
ext2fuse /dev/c/c /mnt/lvm
there is a delay in output but then ..
"/dev/c/c is to be mounted at /mnt/lvm
fuse-ext2 initialized for device: /dev/c/c
block size is 16384"
Dekkit Release Acknowledgements
The original VMware image was found http://www.vmplanet.net/node/85 (before the various patches were applied - so feel free to drop them a donation), if you can improve this image by way of a script to make it even easier to use for us 'non-linux users' then please do so and share it back with the rest of us
Advantages:
Disadvantages:
Background
VMplayer Link
Login to the OS
modprobe fuse
vgscan
vgchange -ay c
mkdir /mnt/lvm
- mdgm-ntgrNETGEAR Employee RetiredWere you using X-RAID?
Disk 2 is the parity disk (has no partition table on it).
You may wish to contact support. - petoulachiAspirantI don't know what was used (X Raid or not), it's not my ReadyNAS.
Support finally answered me, as the ReadyNAS is not under warranty they won't help me. What can I do ? - petoulachiAspirantWell, doing a OS Reinstall again with only Disk 2 allows me to access my NAS again ! I'm backing up the rest of data, I hope it could complete this time !
edit : and I've just checked, disks are in X-Raid indeed - mdgm-ntgrNETGEAR Employee RetiredWell you've got a better chance of it working with disk 2 than with disk 1.
Yes.mdgm wrote: Well you've got a better chance of it working with disk 2 than with disk 1.
After the backup, maybe you can give us SMART stats on the disks.
Upgrading to current firmware, and doing a factory reset with solid disks is the obvious path forwards.
Or upgrade to a new NAS, and let the duo v1 go. - mdgm-ntgrNETGEAR Employee RetiredSplit AusS2000's posts into a separate thread as AusS2000 has a V2 and the VM in this thread is designed for the v1. See http://www.readynas.com/forum/viewtopic.php?f=7&t=77687
- WallyZ21AspirantWhat version of VMWARE should be used, please!
I have tried the Ubuntu image with VMware 6.5 and I certainly can't get it going. It boots without a NAS drive attached but fails to boot when added to the VMware configuration. Log indicates timing out waiting for the drive command to respond, which continually repeats.
The main issue is when adding a physical SATA (raw)drive WMware insists on adding it as an IDE.
I have attempted to manually edit the VMDK and VMX and change te drive from IDE to SCSI as suggested in VMware support forums but still no go.
So if the version of VMware that was used can be stated that may help. - mdgm-ntgrNETGEAR Employee RetiredAnother option would be to boot your PC using a Linux Live CD.
- tlyczkoTutorI lost files on a ReadyNAS Pro 2 with current firmware, 4.2.26, data journaling was off...
Actually all the files in a share are gone.
Just double-checking that this means files MIGHT be able to be recovered if data journaling was disabled...if I can find the right pixie dust..
Only two disks in this NAS, they are in good condition.
Would any Linux software might be able to read them and recover the missing files??
The Dekkit VM might not work for me as it's for an older NAS...ReadyNAS Pro 2 is 'newish' compared to NV+.
What if I booted my notebook with a Linux Live CD and attached the NAS to the notebook -- could something be done that way?? -- but what, how??
I could reinstall Paragon EXTFS drive reader software for Windows but I'm fairly sure it won't read the disk/files based on past experience.
Are there any other good EXT filesystem readers for Windows?? I'm sure the Pro 2 is ext3.
Meanwhile I've shut down that ReadyNAS Pro 2 for now.
Thank you, Tom - mdgm-ntgrNETGEAR Employee RetiredHow did you lose the files?
Did you delete them?
What kinds of files are these?
Do you have a backup?
The Pro 2 would be using EXT4.
