maf11
Sep 23, 2011Aspirant
ReadyNas Duo and Windows 7 Problem
I have just purchased a new laptop, windows 7 64bit. My previous laptop was running XP and everything was fine. I now have problems using the explorer on the shares on the NAS. I am able to see the to...
PapaBear1
Sep 23, 2011Apprentice
A couple of questions -
1. Do you have a user id and password required to log onto your laptop?
2. When you set up the network on your laptop, did you select, home, work or public?
3. Do you have any passwords required on your ReadyNAS?
FWIW - I connect to my 3 ReadyNAS units from two desktops and a laptop all running Win7 HP 64bit.
