maf11
Sep 23, 2011Aspirant
ReadyNas Duo and Windows 7 Problem
I have just purchased a new laptop, windows 7 64bit. My previous laptop was running XP and everything was fine. I now have problems using the explorer on the shares on the NAS. I am able to see the to...
PapaBear1
Sep 28, 2011Apprentice
I should have asked what "Anti-Malware Suite" you were running. Both McAfee and Norton have bad reputations for taking over PC's and not allowing some connections. I used AVG previously and have had no problems with it, although my machines currently have Avast!. I also have SuperAntiSpyware for spyware protection (Pro version) and periodically run Malwarebytes Anti-Malware as well. (You can only have one active Anti-Spyware at a time or they will conflict).
