mrl2000
Nov 17, 2021Aspirant
Readynas duo nv+ v2 failed disk and no boot
Hi I have I think found that disk 4 (of 4) has failed. I found it making that known noise of disk failure, wouldnt reboot, tried again, removed disks checked it would come up with no disks. U...
Nov 17, 2021Guru - Experienced User
mrl2000 wrote:
But I cannot remember how to replace the disk if it wont boot, is it a case of just changing disk 4 for new(hopefully it is that one causing the fault) adn then let it boot(hopefully) and rebuild?
Try booting the system w/o no disk 4, and see if it then boots.
If it does, then hot-insert the replacement disk. It should then resync.
If it doesn't, then you should test all remaining the disks with seatools.
mrl2000
Nov 18, 2021Aspirant
Thanks
It has booted at least looks normal, should I be able to access the volume when a disk has failed and dead?
Just got to wait on delivery for drive tomorrow and plug in and hope for the best.
- StephenBNov 18, 2021Guru - Experienced User
mrl2000 wrote:
should I be able to access the volume when a disk has failed and dead?If you are using XRAID or a RAID mode with redundancy (RAID-1 or RAID-5), then yes.
- mrl2000Nov 18, 2021AspirantThat's interesting as it is a raid mode, can't remember which one, thought it was 2 and 2, but actually all disks are 1tb but total size is 2.9 tb with 2.7tb available.
mrl2000 wrote:
That's interesting as it is a raid mode, can't remember which one, thought it was 2 and 2, but actually all disks are 1tb but total size is 2.9 tb with 2.7tb available.That would be RAID-5 (or XRAID). 4x1TB would give you a 3 TB data volume, with 1 TB used for RAID redundancy. ReadyNAS uses TiB units (1024*1024*1024*1024 = 1 TiB), and that gives 3.85 TiB for the volume size.
