timrim
Aug 07, 2011Aspirant
ReadyNAS Duo refuses to spin down Seagate ST31000524AS
I have 'Enable disk spin-down after..' selected but the two identical 1TB discs refuse to spin down. The logs show no sign of spindown. This is the only info I have...does anyone know of a solution...
mdgm-ntgr
Aug 07, 2011NETGEAR Employee Retired
Could you download the logs (Status > Logs > Download all logs), extract the zip contents and look for references to spinning up and spindown in system.log
If you're running a Mac, you can open the log in the Console and search for a string matching to just look for the references you want.
