Triplet3
May 24, 2025Aspirant
ReadyNAS DUO RND2000V2
I was asked by a friend if I could have a look at her RND2000v2.
It was "not working" anymore.
I started it at my desk, it began to check the disks and started up as far as I can see. I installed RAIDar and it show the device. When I tried to connect the frontview it gave me an error.
It said "unsupported protocol". I edited the Virtual.conf file where I replaced in these lines: RewriteRule ^/admin
https by http.
Now I get the admin prompt when I use http on the NAS/admin but then I get the error:
The requested URL /admin was not found on this server.
And I don't know how to get the networkshares visible in the windowscomputer.
I directly connected the NAS to the networkport of my laptop on which I have set the ip-range in the same range as the NAS is.
Use this instead:
#vers=2 <VirtualHost _default_:80> SSLEngine off # Eliminate HTTPS rewrite # RewriteEngine on # RewriteRule ^/admin/(.*)$ http://%{SERVER_NAME}/admin/$1 [R,L] # RewriteRule ^/admin$ http://%{SERVER_NAME}/admin # End Eliminate HTTPS rewrite </VirtualHost>Then connect with http://nas-ip-address/admin
You can also use https with FireFox. Set security.tls.version.min to 1 (browse to about:config and search for the setting).
- Triplet3Aspirant
I use Firefox with HTTPS, thanks. I had to change the workgroup in windows to be able to use the shares. It works fine now.
