ianhigh
Oct 14, 2016Aspirant
ReadyNAS DUO RND2120 Password reset
I have an old ReadyNAS DUO that has been out of service for a while. The admin password is no longer known, nor is the password recovery answer. My understanding is that the default credentials ...
Oct 14, 2016Guru - Experienced User
ianhigh wrote:
Would still like to know what is the latest firmware I should be using for the above device
4.1.15 - http://kb.netgear.com/app/answers/detail/a_id/30914/~/raidiator-version-4.1.15-(sparc)
If you download and install manually, you need to extract the firmware from the zip file.
ianhigh wrote:
Currently has a single 2Tb - Can I replace with two 4Tb and put into RAID1?
No, the max disk size supported by your older ReadyNAS is 2 TB. It doesn't support GPT formatting.
I'd recommend WD20EFRX (WD "Red") drives for your NAS. Seagate Ironwolf (ST2000VN000) are another option.
ianhigh
Oct 17, 2016Aspirant
Hi Stephenb.
Thanks for your help.
NAS all upgraded and singing like new.
Thanks once again.
