GaryMiller's avatar
GaryMiller
Readynas DUO: Second WD20EARS drive never works.
Hi,
I am new to the forums and totally new to the Netgear ReadyNAS products so excuse me if I do something wrong. I looked at the FAQ but couldn't find a prompt answer to my question.
I bought a Netgear ReadyNAS Duo last Friday and received it on Saturday. During the weekend I ordered two Western Digital CaviarGreen 2TB 64MB SATA hard disks. They came in these afternoon so when I got home from work I attached them to the two things that go in to the NAS and turned the nas on and ran the RAIDar.
Now, the disk that's in slot 1 works fine and is recognized by the NAS and gives a green light. The slot 2 keeps blinking and on the RAIDar it gives a yellow ball on the left that means "warning or dead".
Does this mean that the new disk is dead or that there's maybe something wrong with the NAS? Do I need to configure something first before the second drive works?
Thanks in advance.
Gary Miller
  • I would remove one disk and attach it to an SATA port on the motherboard of a PC and remove the partitions (disk management in Windows will do it nicely). Then start the Duo with the other disk in bay 1. If you have not upgraded to 4.1.7, do so and perform a factory default. Once it has booted and settled down, hot add the second drive in bay two.
    Post back with the results.
  • Hi Ranson,
    I have an almost exact replica of your system (mine is RND2000 Duo (V4.1.7) with two Caviar Green 'WD-20EARX' 2TB disks) and have it working. My set up was complicated by the NAS Duo power supply dying within a couple of minutes of start up meaning my drives were in the process of being configured. Once I received my NAS back with a new power supply, I did the following, noting that my NAS was at firmware V4.1.7 - so you may need to upgrade first.
      Connect the drive to your Windows PC
      Downloaded WD Lifeguard from the Western Digital site
      tested my drives (both were OK)
      performed a quick write zeroes (at the start and end of the drive)
      Using windows administrative tools, (this is a bit hazy - am not sure of the exact steps) check the properties on the raw volume and you get prompted for the boot record type, choose the second for larger drives, NOT the MBR option.
      Install one drive in bay 1 of the NAS (closest to the switch and USB socket)
      Press the reset button on the back next to the rear USB sockets for factory default
      Power up and monitor using RAIDar
    My system now booted fine and initialised OK and then I could configure my system. Once it was working fine, I put in the second drive in bay 2 and the NAS worked properly, recognised the second drive and started synchronising.
    So.. it can be done, but only after I wiped the drives and reset the boot record. Regards, Richard
ProSupport for Business
