IceniTribe
Sep 29, 2016Aspirant
ReadyNAS Duo V1, unable to access Frontview following upgrade to 4.1.15
I have just upgraded to 4.1.15 (having been promted from the NAS box) and now Frontview is not available. I have tried an OS intall from the boot menu but no change, I assume it just reinstalls 4...
- Sep 30, 2016
Do you have port forwarding setup? If so, someone might be trying to hack into your NAS.
You could do e.g.
# mkdir /tmp/tmp1235# cd /tmp/tmp1235
Copy the PHP add-on to that directory and extract the contents of it e.g. if it is called PHP.bin you could do
# dd if=PHP.bin skip=1 | tar -xv
# sh install.sh
Hopefully you are then able to access Frontview again. If not check what error you get. You may need to install other add-ons over the top of themselves or perhaps install a newer version of the PHP Sparc add-on if there is a newer version available.
mdgm-ntgr
Sep 29, 2016NETGEAR Employee Retired
You could try e.g.
# tail -n 20 /var/log/frontview/error.log
If the http/s service is not running this may explain why. If you had e.g. the PHP add-on installed then you may have to install that over the top of itself via SSH to get Frontview back.
IceniTribe
Sep 30, 2016Aspirant
Hi mdgm,
Output from tail command
ReadyNAS:~# tail -n 20 /var/log/frontview/error.log
[Thu Sep 01 06:25:24 2016] [notice] caught SIGTERM, shutting down
[Thu Sep 01 06:25:31 2016] [warn] RSA server certificate CommonName (CN) `192.168.1.64' does NOT match server name!?
Bad free() ignored (PERL_CORE) at /frontview/lib/Frontview.pm line 2.
Bad free() ignored (PERL_CORE) at (eval 2) line 3.
Bad free() ignored (PERL_CORE) at /frontview/lib/get_handler.pm line 2.
Bad free() ignored (PERL_CORE) at (eval 3) line 3.
[Thu Sep 01 06:25:45 2016] [warn] RSA server certificate CommonName (CN) `192.168.1.64' does NOT match server name!?
[Thu Sep 01 06:25:45 2016] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.4.45-0rnx1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Fri Sep 02 06:25:24 2016] [notice] caught SIGTERM, shutting down
[Fri Sep 02 06:25:29 2016] [warn] RSA server certificate CommonName (CN) `192.168.1.64' does NOT match server name!?
[Fri Sep 02 06:25:40 2016] [warn] RSA server certificate CommonName (CN) `192.168.1.64' does NOT match server name!?
[Fri Sep 02 06:25:40 2016] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.4.45-0rnx1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
Any advice most welcome.
