Plucky's avatar
Plucky
ReadyNAS Duo v2 - Replacement HD
Hi
Ive had my Disk 1 show a error of 'Dead' in System --> Info window so I have replace with a
Seagate ST31000524AS drive. Problem I have is Im not sure its synchronizing as I still see the same message
in the  System --> Info window and on the front of the device the blue light is flashing on disk 1.
Ive attached a snap shot of the message.
Is there anywhere in the web portal that shows me its working?
Thanks
Plucky
  • StephenB's avatar
    There should be some messages in the log when the NAS detected the disk insertion and then started to resync.
    If you aren't seeing those, try removing the new disk and then restart the NAS.  Then reinsert the new disk, and see if that works.
    Sometimes when a drive fails the NAS disk drivers will declare the SATA port as down.  In those cases the disk replacement isn't detected.
    • Plucky's avatar
      Plucky
      Hi StephenB
      Thanks for replying
      It looks like its rebuilt disk 1 but now is telling me disk 2 could be faulty but the status for disk 2 is OK.
      Disk 1 is showing a yelow circle with a red cross through it and status is inactive.
ProSupport for Business
