Atters
Dec 21, 2022Aspirant
ReadyNAS Duo v2 Access
Hi Support I have a nwe windows 11 latop and cannot access the Nasdrive. Nasdrive has a fixed ip address on the network. Cannot connect to mapped drives either. Laptop has Chrome and Edge i...
Dec 21, 2022Guru - Experienced User
Atters wrote:
Hi Support
FYI, not Netgear Support - this is a user-to-user forum.
Go into "turn windows features on or off" and enable the SMB 1/CIFS client. Then entering \\nas-ip-address into the explorer address bar should show you the shares. Use the real IP address of course, and be careful to use the correct slash.
Atters wrote:
Laptop has Chrome and Edge installed, when I try to install inetexplorer I get a "not compatable with windows 11" error.
You can try Edge in IE mode (just google it). That is supposed to work, but some folks have struggled with it.
You can also download an old version of FireFox - 94.0.2 will work. Don't let it auto-update. More info is here:
Note there is an add-on for the v2, but not for the original Duo (v1). Many owners of the original Duo mistakenly think they have a v2.
The original Duo (v1)
- runs 4.1.x firmware
- says ReadyNAS Duo on the front panel
- may have other labels that say v2
The Duo V2
- runs 5.3.x firmware
- says ReadyNAS Duo v2 on the front panel
Atters
Dec 22, 2022Aspirant
Hi support
The Edge compatability toggle works. Thx. I can now see the ReadyNAS on the Window11 laptop. It is not allowing me to log on though.
I have access to the ReadyNAS via an older laptop. The ReadyNAS access is set to users (not active directories). So question is, what is the user from a windows 11 laptop. It does prompt me or password for "Microsoft/'email address'". Do I create a user as prompted or do I have to change a setting in Windows 11?
Thx
- StephenBDec 22, 2022Guru - Experienced User
You can use the same username/password as you use on the older laptop - or if you wish, you can create a new user account on the NAS.I don't believe the email username format used in Microsoft accounts is accepted by your NAS. But you can set the default username the PC will use when accessing the NAS using the Windows Credential Manager. You can also save the password ther if you wish.
Note that Windows treats the NAS hostname and the IP address as different machines - so if you access using both, you will need to set up two credentials (which can be identical if you wish).
Just to be clear - this is a user-to-user forum, and I do not work for Netgear.
