Atters
Dec 21, 2022Aspirant
ReadyNAS Duo v2 Access
Hi Support I have a nwe windows 11 latop and cannot access the Nasdrive. Nasdrive has a fixed ip address on the network. Cannot connect to mapped drives either. Laptop has Chrome and Edge i...
Atters
Dec 22, 2022Aspirant
Hi support
The Edge compatability toggle works. Thx. I can now see the ReadyNAS on the Window11 laptop. It is not allowing me to log on though.
I have access to the ReadyNAS via an older laptop. The ReadyNAS access is set to users (not active directories). So question is, what is the user from a windows 11 laptop. It does prompt me or password for "Microsoft/'email address'". Do I create a user as prompted or do I have to change a setting in Windows 11?
Thx
Dec 22, 2022Guru - Experienced User
You can use the same username/password as you use on the older laptop - or if you wish, you can create a new user account on the NAS.
I don't believe the email username format used in Microsoft accounts is accepted by your NAS. But you can set the default username the PC will use when accessing the NAS using the Windows Credential Manager. You can also save the password ther if you wish.
Note that Windows treats the NAS hostname and the IP address as different machines - so if you access using both, you will need to set up two credentials (which can be identical if you wish).
Just to be clear - this is a user-to-user forum, and I do not work for Netgear.
