Krogagre
Sep 23, 2015Aspirant
ReadyNAS Duo v2 failure, how to save data on disks
I had a power outage today which took out my Duo v2, the disk 2 seem to be ok still I have tried to mount the disk on my windows 10 using ext2fsd but get the disk mounted in 4 partitions all as R...
mdgm-ntgr
Sep 23, 2015NETGEAR Employee Retired
Can you confirm this is a Duo v2 after reading this article: http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
The procedures for the Duo v1 and the one for the Duo v2 are very different to each other.
Your support profile indicates you have a v1.
