emu83
Nov 05, 2014Aspirant
ReadyNAS Duo V2 No Volume. Please help me.
Hi Been trying to solve the problem myself but failed all the way :( After moving house my readynas duo v2 can't see any volume. It has 3TB Seagate disks inside with no Raid so all 6TB is used w...
mdgm-ntgr
Nov 05, 2014NETGEAR Employee Retired
Contact support.
In future I would recommend that you backup your data. No important data should be stored on a single device.
Furthermore if your data is important to you RAID-0 and JBOD are bad choices. RAID-1 and X-RAID with multiple disks provide some protection against a disk failure.
