emu83
Nov 05, 2014Aspirant
ReadyNAS Duo V2 No Volume. Please help me.
Hi Been trying to solve the problem myself but failed all the way :( After moving house my readynas duo v2 can't see any volume. It has 3TB Seagate disks inside with no Raid so all 6TB is used w...
Nov 10, 2014Guru - Experienced User
This isn't Netgear support, it is a community forum.
You can power down the unit and check the drives on a PC with Seatools. That would confirm their status.
If you have a spare disk, you can insert it (by itself) in the duo v2, and see if the NAS does an install on the spare disk. That would confirm that the NAS hardware is working properly.
