llevet's avatar
llevet
ReadyNAS Duo v2 services
Hi,
I 'm just see the new Duo V2, but i'm surprise it use only CIF service !!!
Why have you remove NFS (streaming to lot of media player, remote share for linux ...) and RSYNC (backup from other linux or nas ...) ? They are widely used !
Is there any chance to come back ?
Thank's.
Ludo.
  • Hi All,
    Not sure if this has been covered before but ..... if you want to enable ftp on the ReadyNAS Duo v2 then ....
    Use EnableRootSSH to good effect!
    Login as root, and cd to /etc/default
    edit the services file (vi services)
    Change the line "PROFTPD=0" to "PROFTPD=1"
    Save the change
    reboot
    When the ReadyNAS reboots the proftpd daemon will start automagically. You cannot use either the root or admin logins for ftp services. You need to create a new user and home directory as follows.
    useradd ftpuser
    passwd ftpuser (Make it a secure one!)
    mkdir /home/ftpuser
    chown /home/ftpuser
    Now you can login via ftp as the user ftpuser.
    Have fun!
    Ripface.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Personally I wouldn't add users that way. I'd add them via the Dashboard and setup the FTP shares for them as is done on the other ReadyNAS models. Especially considering FTP is planned to be added as a feature.
  • Hi mdmg,
    Thanks for the feedback. Always an option using the Dashboard. I guess if the option to switch on FTP had been put there you wouldn't need to login via ssh as root at all. Does anyone have any idea *why* they switched it off by default and then prevent normal "noob" users from activating it? Seems a weird thing to do!!
    Cheers,
    Ripface.
    mdgm-ntgr
    What I'm saying is that I'd enable FTP via SSH, but I'd create the users via the Dashboard then edit the proftpd config under /etc/frontview/proftpd
    FTP is planned for 5.3.4. So another alternative would be to wait for that. There has been a fair bit of demand for FTP.
ProSupport for Business
