PlanAndSimple
Jan 13, 2014Aspirant
Readynas integration
Hi, is the ReadyNAS Pro 2 compatible with UTM 150 for setting up quarantine?
- xeltrosApprenticeHi,
I found nothing for quarantine on the product description from Netgear. I'm not familiar with Netgear security products.
What do you call quarantine ? is it 802.1X authentication for ethernet, DMZ isolation, virus scan quarantine... ?
Do you plan on buying one of those products or is it just a setup matter ? - chirpaLuminaryYou can install the UTM add-on on the Pro 2.
