raebel
May 31, 2018Aspirant
ReadyNAS login problem
Hi, i have a problem with my ReadyNAS Duo 2000. It has got 2x 1TB WD Enterprise-class HDDs installed. model: ReadyNASRND2000 I can ping the device but I cant login through webinterface. I did ...
- May 31, 2018
Hi raebel,
Welcome to the Community!
The default admin credential for the ReadyNAS Duo v1 is admin for the username and netgear1 for the password.
You may try using the older version of RAIDar, which is the 4.3.8, and see if it can detect the NAS.
JohnCM_S
May 31, 2018NETGEAR Employee Retired
Hi raebel,
raebel
Thanks a lot.
I was confused because it says RND2000 v2 at the bottom of the NAS.
So i read the wrong documentation.
After upgrading the firmware, RAIDar 6.3.0 works fine now.
Thanks for your support.
Cheers
Sebastian
