Fandaor
May 27, 2012Aspirant
Readynas NV+ : Fan plug is burned...
Hello there, I just had a very weird situation : last friday I received alerts from the nas telling me temp issues and the fact the fan was no longer connected. When I came back home the nas was ...
PapaBear1
May 27, 2012Apprentice
You subject says the fan plug is burned. Is the connector on the backplane board in fact burned or just not working?
In either case, if your unit is still under warranty, then you should open an on line tech support case. If your unit is an Infrant, it is out of warranty unless the PSU has gone bad.
