ownaish
Oct 25, 2010Aspirant
ReadyNAS NV+ and 2TB disks?
Hi there I'm wondering whether I can really expand my ReadyNAS NV+ now with 2TB disks. At the time where I bought it (some years ago) the highest supported disk size was 750GB. I do have two of them....
TeknoJnky
Aug 10, 2011Hero
https://encrypted.google.com/search?q=WD20EARX
from the results it looks like EARX is an EARS with a sata3 controller (6gbs)
as for whether it works, about the only thing your gonna be able to do, is try it and tell us if it works for you.
