ownaish
Oct 25, 2010Aspirant
ReadyNAS NV+ and 2TB disks?
Hi there I'm wondering whether I can really expand my ReadyNAS NV+ now with 2TB disks. At the time where I bought it (some years ago) the highest supported disk size was 750GB. I do have two of them....
mdgm-ntgr
Sep 07, 2011NETGEAR Employee Retired
There are alternative drives from other manufacturers that you can use. Whilst the WD20EARX may work fine if you encounter issues you may be denied support. With the WD20EARX you would still have the issue of needing 4k sector alignment (which would require you last factory reset - wipes all data, settings, everything on 4.1.7 or later).
