z0mb13
Jun 05, 2013Aspirant
ReadyNAS NV+ and 3TB HDD
Hello, I'm trying to find information about the possibility to use 3TB hdd with the NV+ NAS device. In detail if the hdd Seagate Barracuda 7200.14 ST3000DM001 3 TB it's compatible. Thank you so m...
mdgm-ntgr
Jun 05, 2013NETGEAR Employee Retired
The NV+ (v1 - silver chassis, runs RAIDiator 4.1.x or earlier) supports disks of up to 2TB in capacity
The NV+ v2 (charcoal chassis, runs RAIDiator 5.3.x) supports some 3TB disks.
See the HCL (choose Legacy and then select the NV+ or NV+ v2 depending on which model you have).
