sridgway
Jan 15, 2013Aspirant
ReadyNAS NV+ Disk Failure
I have owned a ReadyNAS NV+ for over 4 years and it has never missed a beat since I set it up. it was setup up with 4 x Seagate ST31000340AS 1000 GB Hard Drive Late last year I began receiving e...
sridgway
Jan 23, 2013Aspirant
thanks for that, I had never clicked that button before I had mainly relied on the logs for information, just goes to show you learn something new every day :>
here are the current stats for the 3 of the 4 drives. Drive 1 is the new drive and 2,3 and 4 are the pre existing segate drives. Disk 4 looks to have some relocated disk errors and I have had a couple of notifications regarding this drive in the past. Over the next month or so I might replace all the remaining drives.
Thanks for your support
SMART Information for Disk 1 (WDC WD20EFRX-68AX9N0 1862 GB)
Model: WDC WD20EFRX-68AX9N0
Serial: WD-WMC300371955
Firmware: 80.00A80
SMART Attribute
Raw Read Error Rate 0
Spin Up Time 4125
Start Stop Count 19
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 59
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 6
Power-Off Retract Count 5
Load Cycle Count 13
Temperature Celsius 29
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 771
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 2 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0ZBZD
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12451
Power On Hours 30070
Spin Retry Count 46
Power Cycle Count 96
End-to-End Error 0
Reported Uncorrect 0
Command Timeout 4
High Fly Writes 62
Airflow Temperature Cel 34
Temperature Celsius 34
Head Flying Hours 125559073954558
Total LBAs Written 1506392878
Total LBAs Read 4220859648
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 26
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 3 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0QXTK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12462
Power On Hours 30069
Spin Retry Count 86
End-to-End Error 0
Command Timeout 3
High Fly Writes 26
Airflow Temperature Cel 38
Temperature Celsius 38
Head Flying Hours 242407954209551
Total LBAs Written 1543315895
Total LBAs Read 371866688
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 257
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
SMART Information for Disk 4 (Seagate ST31000333AS 931 GB)
Model: ST31000333AS
Serial: 9TE0Z8CK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Start Stop Count 12470
Reallocated Sector Count 40
Spin Retry Count 204
End-to-End Error 0
Command Timeout 4
High Fly Writes 1528
Head Flying Hours 168822279527031
Total LBAs Written 1421001211
Total LBAs Read 732597788
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 2
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Firmware: 80.00A80
SMART Attribute
Spin Up Time 4125
Start Stop Count 19
Seek Error Rate 0
Power On Hours 59
Spin Retry Count 0
Power Cycle Count 6
Load Cycle Count 13
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 771
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Model: ST31000333AS
Serial: 9TE0ZBZD
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Spin Retry Count 46
End-to-End Error 0
Command Timeout 4
High Fly Writes 62
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 26
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Model: ST31000333AS
Serial: 9TE0QXTK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
Spin Retry Count 86
End-to-End Error 0
Command Timeout 3
High Fly Writes 26
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 257
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
Model: ST31000333AS
Serial: 9TE0Z8CK
Firmware: CC1F
SMART Attribute
Spin Up Time 0
End-to-End Error 0
Command Timeout 4
ATA Error Count 0
Extended Attribute
Hot-add events 0
Hot-remove events 0
Lp stat events 2
Power glitches 0
Hard disk resets 0
Retries 0
Repaired sectors 0
