Flockhammer
Apr 04, 2020Tutor
ReadyNAS NV+ Frontview loads to home screen but nothing happens when I click any options.
So i have an issue where I cant get anyof my options to load on the FrontView page no matter what browser I use. Chrome, Firefox, Edge, IE, and Opera. I can login to the admin page no issue and the home screen loads up but as soon as I try and access anything under Network, Security, Services, Volumes and on down the list I only received a blank screen where it should be loading. Screen shots below. Ive tried enabling Flash on every browser and doing a refresh but still no luck. Any help would be awesome.
I was able to get this sworted out. It ended up being a subnet issue on my network. Once I was able to get everything on the same subnet the admin page started working as it should. Thanks for the help.
Flash isn't used, so that's not a factor. You might try using incognito mode in Chrome and see if that works.
Have you tried rebooting the NAS?
Also, what firmware are you running?
Same issue when using incognito mode in Chrome.
Firmware: RAIDiator 4.1.16 [1.00a043]
It is working with my own NAS (also running 4.1.16) using Chrome as the browser.
Something is definitely wrong. Do you have a backup of the data? Is ssh enabled on the NAS?
