mtkeane
Jun 20, 2014Aspirant
ReadyNAS NV+ Hanging...think it's a bad disk
3 times over the past 2 weeks my ReadyNAS NV+ has hung...I can't access shares or FrontView. I have to do a hard boot by pulling the power cable. Once it comes back up it does a resync which takes a...
Jun 21, 2014Guru - Experienced User
These stats look pretty reasonable to me.
The main thing that jumps out at me is the "program fail" count for drive 2. Though the description of that stat isn't all that clear, it sounds like it refers to a program failure within the drive (e.g. the drive firmware). Though seagates don't usually report that particular parameter, it is reported on that drive because it was developed by Samsung.
And of course there are the uncorrectable errors on drive 3.
So maybe start with an extended test of drive 2 and 3.
CRC errors and command timeouts could be a NAS problem, they aren't necessarily the fault of the drives.
- Aug 06, 2024Retired_Member
