smokeisbad
May 16, 2015Aspirant
ReadyNAS NV+ inaccessible hard drives
Hi, I'm using a ReadyNAS NV+ for several years now and I never experienced any problems at all. 4 days ago, I rebooted my nas and suddenly I wasn't able to access it from my PC. I launched Raid...
smokeisbad
Yes it does come up as I used it to upgrade the firmware (USB boot).
I also tried to remove the HDDs and put a new one in it then I did a factory reset.
Nothing worked.
I'll try to contact the netgear support and see what they suggest, but I think that if the HDD isn't in the list of supported drives they'll just refuse to help.
Nothing worked.
