turick
May 20, 2012Aspirant
ReadyNAS NV+ lockups
I have an NV+ with the latest firmware (4.1.8) and 4 2TB WD Green SATA II hard drives (WD20EARS) in an X-RAID configuration. I primarily use the NAS to store movies, music, and TV shows that everybod...
arjoseph1
May 23, 2012Tutor
Check the disk smart logs and find which disk has "Re-allocated sectors", Current Pending Sector" and ATA errors. Or you may contact support for a much better diagnosis. Once you get a case #, please edit the subject of your post and add the case # at the end. Thanks.
