turick
May 20, 2012Aspirant
ReadyNAS NV+ lockups
I have an NV+ with the latest firmware (4.1.8) and 4 2TB WD Green SATA II hard drives (WD20EARS) in an X-RAID configuration. I primarily use the NAS to store movies, music, and TV shows that everybod...
Sep 26, 2012Guru - Experienced User
I suggest opening a support ticket. I'd also check the SMART+ stats on the disks, and look at the ethernet stats for transmission/reception errors.
