Doogz
May 12, 2012Aspirant
ReadyNas NV+. No response, will not power off. Help
Hello, I have an NV+. Everything was working a few months ago. I could access via readynas remote with no problem. I work away from home quite a bit & while on last trip I could no longer co...
Doogz
May 19, 2012Aspirant
Hmmm... returned home, read the manual & seen that it is OK to pull the plug if unit is non responsive with power button. Re-booted & re-installed OS as per manual. Everything seems to be working fine. Just in case anyone esle has the same problem read the manual 8-)
