AndrewWykes's avatar
AndrewWykes
ReadyNas NV+ Overheated - how do I salvage my data?
I have had this machine for years and has worked well. Recently, due it it being dusty (my fault), it seems to have overheated and now won't switch on.  To sure if it has a fuse or it's the power supply, or the whole unit has had it.
I no longer want to use it as its very old and want to move the data to something more modern.
What is the best approach to get all my data?
It has 4 discs in and is mirrored.
Any help would be appreciated!
Thanks
Andrew
  • StephenB's avatar
    Can you connect all the disks to a PC - either with USB adapter/docks or SATA?
    • AndrewWykes's avatar
      AndrewWykes
      Hi Steven. I have an Apple Mac.
      You helped me 4 years ago with a different problem with the same unit so thank you very much for your help. I appreciate it.
      • StephenB's avatar
        R-Studio for Windows can recover the files.  There is a version for Mac that I think will work, but it would be best to contact R-Studio and ask.  Cost is reasonable, but you'd also need to a way to connect the disks to the Mac.  USB adapter/docks would work.  https://www.r-studio.com/data_recovery_macintosh/
        The problem with the NV+ is likely to be the power supply (PSU).  That can be replaced for a roughly similar cost. In your earlier post, you identified the model as a v1 - which runs 4.1.x firmware.  If you replace the PSU (or try to purchase a compatible NAS), we should confirm the model details.  A "v1" NAS will say "ReadyNAS NV+" or "ReadyNAS Duo" on the front panel.  A "v2" runs 5.3.x, and will say "ReadyNAS NV+ v2" or "ReadyNAS Duo v2" on the front panel.
        The risk there is that the failure might also have damaged the system board - if that's the case the PSU won't be enough.  A v1 NAS will be at least 10 years old.  The v1 design goes back to ~2006, and Netgear ended production in 2011.  The v2 is also pretty old at this point - Netgear ended production back in 2013.  So even a well-cared for used model might not last very long.
        Though my own NV+ v1 and Duo v1 are both still running, I only use them as secondary backups, so I don't depend on them.  If you do repair the NAS (or purchase a compatible used NAS), I suggest investing in a newer storage solution.
ProSupport for Business
