wb26's avatar
wb26
Star
Feb 04, 2025
ReadyNAS NV rnv1-s2-0000 can’t connect
Hello everyone- my old ReadyNAS NV (Infrant Ready label) powers up, I can ping it successfully but cannot access the files on the drives. Tried remapping the drives in file manager but the connection fails. I also can’t access the NAS web interface. The status lights on on the front show 4 solid green for the drives, the blue power LED flashes somewhat slowly 12 times then the activity green LED flashes once, then 12 more flashes of the blue power LED, and this repeats. Could not locate any info on what this LED sequence indicates. Any of you know?
Is my trusty NAS finally dead? Most data is backed up but I have about 6 months of new data that I neglected to backup that I can hopefully recover.
If all else fails can I buy an old chassis and put the drives in there to recover my data or is there another method I can use to recover the data?
Any guidance on troubleshooting is greatly appreciated. Thank you.
  • StephenB's avatar
    Have you tried RAIDar?  It might give you more information.
    I suggest testing the disks in a Windows PC with vendor tools (Seatools for Seagate, Dashboard for Western Digital).  Run the short test first, if that passes then run the long test.  You can connect the disks with a USB adapter/dock.
    There are of course other possibilities, including a memory failure.
    As far as recovery goes, you could also get a 4-bay enclosure and use R-Studio (or similar RAID recovery software) to recover data.
    You'd need the $79.99 license.
    What error are you getting?
    • wb26's avatar
      wb26
      Star
      RAIDar does not work on my windows 10 system. I also tried running RAIDar in windows 7 compatibility mode but no luck. Is there a version that is compatible with windows 10?
      Will R-Studio work if I configured the NAS as X-RAID?
      When I try to access the admin interface at http://192.168.1.80/admin I get a can’t reach this page error even though the can ping the address successfully.
      Any idea what the blinking power LED indicates?
      Once on, the NAS is also difficult to power down. Only way I can power down is to hold the powering button down for about one minute.
      Thanks
      • StephenB's avatar
        Yes.  Do you know what firmware the NAS is running?
    • Sandshark's avatar
      Sandshark
      Sensei
      How does it behave and what does RAIDar indicate with the drives removed?
ProSupport for Business
