arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find the NAS.
From other posts it sounds like one possible cause is overflowing log files. Is there any way to clear these, or verify if this is the issue? I can't get into 'setup' as the file check doesn't reach completion.
Due to human error, my backup is several months out of date. The missing information is music from CDs, so I could recreate it, but it would be very time consuming. Ideally I would like to resolve the NAS issues and get it back up and running.
Thanks
Rennie
Have you tried skipping the check with the boot menu?
If your NV+ says "ReadyNAS NV+" on the front panel, then the instructions are on pages 23-24 here:
If it says "ReadyNAS NV+ v2" on the front panel, then the instructions are on pages 24-25 here:
Hi Stephen,
Thanks for the quick response. It is an NV+. I hadn't tried skipping the check with the boot menu. In fact I didn't know you could do that. That was a definite step forward. RAIDar now runs fully, and my PC sees the NAS and I can access the files. I can see that the firmware version is 4.1.16. I am not sure what I should do next to restore the NAS to its previous condition. My instinct is to connect one of the backup disks to see if the scheduled backup runs. The NAS has four 1TB disks. However, presumably one or more of the NAS disks has some kind of issue which needs to be resolved. I don't know if it is relevant, but during the boot process a message came up on the screen saying that 'Disk 2 was syncing'. None of the other disks were mentioned.
A secondary issue I have is that when I click on the Setup button I get a security message from the browser that it does not support TLS 1.2 protocol. I have tried with several browsers, but none allow Setup to load, so I am not sure how to get round that.
Cheers
Rennie
Great. BTW, 4.1.16 is the most recent (and final) firmware for your NAS.
It is relevant - resyncing means the disk contents were reconstructed (using RAID parity) from the other disks. This will happen when you replace a disk, but there are also situations where the array gets out of sync. In this case, some writes to disk 2 probably never completed - perhaps due to a system crash or power loss. Whatever the cause, the system detected it, and automatically rebuilt it.
There could still be some file system issues (caused by whatever triggered the resync), so there could still be some lost or corrupted files. If the resync has completed, you could try restarting the NAS normally and see if that completes. But I do suggest getting an up-to-date backup first.
That makes sense, and in parallel you can work to get back access to frontview.
To clarify, the issue is that the NAS doesn't support TLS 1.2 - most browsers deprecated TLS 1.0 a few months back.
If you use a version of Windows that still has Internet Explorer installed, you can still connect with that - manually browsing to https://nas-ip-address/admin (substituting the real IP address of course). Edge in IE mode should also connect ( https://pureinfotech.com/enable-ie-mode-microsoft-edge-chromium/ has a useful guide).
Another option (useful for either Macs or Windows PCs) is to download an older version of FireFox (version 94.0.2 will work). Make sure you don't let the browser update during the install, and right after the install completes, disable auto-update. If you are comfortable with ssh, there is a configuration file in the NAS that you can change to let you reach frontview with ordinary (unencrypted) HTTP. Or you can make sure you keep the older browser around, and only use it to access the NAS.
More information on this is here:
- SamirDProdigy
It really depends on what your goal is at this point. If you have a backup of the data and simply want to restore the nas, I would 'nuke it from orbit' and start again, just reset it it with one wiped drive and rebuild from there.
The message has moved on to 'resyncing disk 2', but has been stuck at that for several days. I've decided to move on and replace the disks. My brother might have a go at the Linux recovery route, but at the moment, I'm going to start afresh with new disks to create a blank system, and install the out of date backup, and then re-build. My question now is, is there a procedure for adding the new blank disks that will preserve the existing NAS settings?
