arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
Oct 20, 2022Guru - Experienced User
arefem wrote:
I hadn't tried skipping the check with the boot menu. In fact I didn't know you could do that. That was a definite step forward. RAIDar now runs fully, and my PC sees the NAS and I can access the files. I can see that the firmware version is 4.1.16
Great. BTW, 4.1.16 is the most recent (and final) firmware for your NAS.
arefem wrote:
I don't know if it is relevant, but during the boot process a message came up on the screen saying that 'Disk 2 was syncing'.
It is relevant - resyncing means the disk contents were reconstructed (using RAID parity) from the other disks. This will happen when you replace a disk, but there are also situations where the array gets out of sync. In this case, some writes to disk 2 probably never completed - perhaps due to a system crash or power loss. Whatever the cause, the system detected it, and automatically rebuilt it.
There could still be some file system issues (caused by whatever triggered the resync), so there could still be some lost or corrupted files. If the resync has completed, you could try restarting the NAS normally and see if that completes. But I do suggest getting an up-to-date backup first.
arefem wrote:
My instinct is to connect one of the backup disks to see if the scheduled backup runs.
That makes sense, and in parallel you can work to get back access to frontview.
arefem wrote:
A secondary issue I have is that when I click on the Setup button I get a security message from the browser that it does not support TLS 1.2 protocol. I have tried with several browsers, but none allow Setup to load, so I am not sure how to get round that.
To clarify, the issue is that the NAS doesn't support TLS 1.2 - most browsers deprecated TLS 1.0 a few months back.
If you use a version of Windows that still has Internet Explorer installed, you can still connect with that - manually browsing to https://nas-ip-address/admin (substituting the real IP address of course). Edge in IE mode should also connect ( https://pureinfotech.com/enable-ie-mode-microsoft-edge-chromium/ has a useful guide).
Another option (useful for either Macs or Windows PCs) is to download an older version of FireFox (version 94.0.2 will work). Make sure you don't let the browser update during the install, and right after the install completes, disable auto-update. If you are comfortable with ssh, there is a configuration file in the NAS that you can change to let you reach frontview with ordinary (unencrypted) HTTP. Or you can make sure you keep the older browser around, and only use it to access the NAS.
More information on this is here:
arefem
Oct 20, 2022Star
Hi Stephen,
I've left a backup disk plugged in to hopefully run a scheduled backup overnight. I'm not too optimistic, because for some reason, after being connected for a time the NAS seems to become unreachable.
I've installed FireFox version 94.0.2 ready to try with Frontview tomorrow or at the weekend. I've no experience of SSH, but I have a brother who works in IT support, so I'm hoping he can help (unfortunately he is on holiday until the week after next).
Cheers,
Rennie
- arefemNov 24, 2022Star
Hi,
I have not been able to spend time on this in the last few weeks, but I'm able to pick it up again now. The latest position is that it now does not get past the disk 2 sync on bootup. I was unable to run a backup, so unless there is something else worth trying, I am thinking that the only option left is to try replacing disc 2 and see if it rebuilds. If that is the best way to proceed, should I do the swap with the NAS powered off?
I was briefly able to access Frontview, and I can't remember the exact wording, but it indicated that disk 3 was beginning to exhibit errors so should be replaced soon. So I am assuming that the best case scenario is that I have to replace two disks, but there is also a risk that disk 3 has now failed, and all I can do then is a clean build.Cheers
Rennie
- SandsharkNov 25, 2022Sensei
It is best to do the drive swap with power on. If a second drive is bad, or goes bad during the re-sync, then you will have to do a complete re-build. And an already failing drive is very much at risk of total failure during the heavy load of a re-sync.
So, make sure that backup really is up to date. You may also want to just bite the bullet and replace both drives and re-build, which will require only one sync, not two and is going to have a lower possibility of drive failure.
- arefemNov 26, 2022Star
Thank you for the advice. Unfortunately, my backup isn't up to date, due to human error. However, with some effort, I can rebuild it. All the document type files are also saved in the cloud, as are any new photographs. The main inconvenience will be a fairly large quantity of music CDs which will need to be ripped again.
Given that the worst case scenario is a full rebuild, I think I will take the risk of a disk failing, and start off with replacing disk 2, which at the moment is failing to sync. If by a stroke of luck that works, then I will try replacing disk 3 next, as there was a report of that being in bad shape. If I have to resort to a full rebuild, both of those will need replaced anyway. Looking on the bright side, it will be an opportunity to start upgrading the disks from 1GB to 2 GB.
I will report back on progress.
