arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
Dec 09, 2022Guru - Experienced User
arefem wrote:
Unfortunately rebooting with drive 2 removed, and skipping the volume check hasn't worked. It never gets past:
Booting . . .
Resyncing volume.
The LED for disk 2 is flashing, and the blue power light is flashing.
I'm not sure what I should try next. Should I try putting a replacement disk into slot 2?
It looks like it is still trying to access disk 2.
Maybe power down, and remove the mains power for a few minutes. Then try booting up again (still skipping the volume check).
arefem
Dec 09, 2022Star
No change I'm afraid - the behaviour is just the same.
