arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
Dec 10, 2022Guru - Experienced User
SamirD wrote:
If everything auto configures.
It is possible to install the tools needed and manually assemble/mount the volume with Linux. But it won't happen automatically with the NV+.
SamirD wrote:
If you already have a replacement disk for #2, I would try again and this time put in the new disk.
This makes sense, but definitely use the boot menu to skip the volume check. Hopefully the resync will succeed.
arefem
Dec 10, 2022Star
Thanks to you both - I need to go out just now, but I will try that later today.
