arefem
Oct 17, 2022Star
ReadyNAS NV+ stall during File System check at 19%
My ReadyNAS NV+ is stalling during the File System check at 19%. It is visible in RAIDar, and all four disks register as healthy, until the 19% point is reached, at which point RAIDar cannot find t...
Dec 16, 2022Guru - Experienced User
arefem wrote:
I've tried with the new disk replacing disk 2, and using the boot menu to skip the volume check. I'm afraid it still doesn't get past
Booting . . .
Resyncing volume.
Well, it does need to resync the volume. How long are you waiting for that to complete?
Have you tried accessing Frontview (or seeing if the shares are accessible)?
arefem
Dec 16, 2022Star
I left it resyncing for about 2 days.
Sadly I can't access it through Frontview, or view the shares.
Cheers
Rennie
- SandsharkDec 17, 2022Sensei
What brand and model drive did you use? If it's an SMR drive (most smaller desktop and WD Red drives). it will take a long time, though 2 days still seems a lot.
