ClausH42's avatar
ClausH42
Readynas NV+ stuck at booting - missing shares found
Hello,   i have an issue with on of my NV+ v1 which worked for long without an issue (configuration X-Raid). Some days ago when i checked the display after not being able to access the data i found...
  • ClausH42's avatar
    ClausH42
    Oct 10, 2015
    I had a look at the etc/fstab using vi and found a large discrepancy between the fstab of my two NV+
    the nv+ that does not finish boot:
    ***** File system check performed at Sun Oct  4 13:28:32 CEST 2015 *****
    fsck 1.40.11 (17-June-2008)
    WARNING: bad format on line 2 of /etc/fstab
    WARNING: bad format on line 4 of /etc/fstab
    WARNING: bad format on line 5 of /etc/fstab
    WARNING: bad format on line 6 of /etc/fstab
    WARNING: bad format on line 7 of /etc/fstab
    WARNING: bad format on line 8 of /etc/fstab
    WARNING: bad format on line 9 of /etc/fstab
    WARNING: bad format on line 10 of /etc/fstab
    WARNING: bad format on line 11 of /etc/fstab
    WARNING: bad format on line 12 of /etc/fstab
    WARNING: bad format on line 13 of /etc/fstab
    WARNING: bad format on line 14 of /etc/fstab
    e2fsck 1.40.11 (17-June-2008)
    fsck.ext3: No such file or directory while trying to open /dev/c/c^M
    The superblock could not be read or does not describe a correct ext2
    filesystem.  If the device is valid and it really contains an ext2
    filesystem (and not swap or ufs or something else), then the superblock
    is corrupt, and you might try running e2fsck with an alternate superblock:
        e2fsck -b 8193 <device>
    - fstab 1/33 3%
    /dev/hdc2       none    swap    sw                              0 0
    /dev/hde2       none    swap    sw                              0 0
    /dev/hdg2       none    swap    sw                              0 0
    proc            /proc   proc    defaults                        0 0
    /dev/c/c        /c      ext3    defaults,noatime,user_xattr,acl,user_xattr,user_
    /dev/hdc1       /       ext3    defaults,noatime                        0 1
    and the nv+ that is up and running:
    # <device>         <mount>              <type>     <options>    <freq> <pass>
    /dev/hdc1          /                    ext2       defaults,noatime      0
    /dev/hde2          swap                 swap       defaults          0      0
    /dev/hdc2          swap                 swap       defaults          0      0
    /dev/hdg2          swap                 swap       defaults          0      0
    /dev/c/c           /c                   ext2       defaults,acl,user_xattr,usrqu
    the one that is not running shows an ext3 filesystem, whereas the running one shows ext2. As far as i know i never changed this, but what i find more interesting is the long text before the fstab data starts. Even if i do not understand what it tries to tell me
ProSupport for Business
