ClausH42
Oct 08, 2015Aspirant
Readynas NV+ stuck at booting - missing shares found
Hello, i have an issue with on of my NV+ v1 which worked for long without an issue (configuration X-Raid). Some days ago when i checked the display after not being able to access the data i found...
- Oct 10, 2015
I had a look at the etc/fstab using vi and found a large discrepancy between the fstab of my two NV+
the nv+ that does not finish boot:
***** File system check performed at Sun Oct 4 13:28:32 CEST 2015 ***** fsck 1.40.11 (17-June-2008) WARNING: bad format on line 2 of /etc/fstab WARNING: bad format on line 4 of /etc/fstab WARNING: bad format on line 5 of /etc/fstab WARNING: bad format on line 6 of /etc/fstab WARNING: bad format on line 7 of /etc/fstab WARNING: bad format on line 8 of /etc/fstab WARNING: bad format on line 9 of /etc/fstab WARNING: bad format on line 10 of /etc/fstab WARNING: bad format on line 11 of /etc/fstab WARNING: bad format on line 12 of /etc/fstab WARNING: bad format on line 13 of /etc/fstab WARNING: bad format on line 14 of /etc/fstab e2fsck 1.40.11 (17-June-2008) fsck.ext3: No such file or directory while trying to open /dev/c/c^M The superblock could not be read or does not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> - fstab 1/33 3% fsck 1.40.11 (17-June-2008) WARNING: bad format on line 2 of /etc/fstab WARNING: bad format on line 4 of /etc/fstab WARNING: bad format on line 5 of /etc/fstab WARNING: bad format on line 6 of /etc/fstab WARNING: bad format on line 7 of /etc/fstab WARNING: bad format on line 8 of /etc/fstab WARNING: bad format on line 9 of /etc/fstab WARNING: bad format on line 10 of /etc/fstab WARNING: bad format on line 11 of /etc/fstab WARNING: bad format on line 12 of /etc/fstab WARNING: bad format on line 13 of /etc/fstab WARNING: bad format on line 14 of /etc/fstab e2fsck 1.40.11 (17-June-2008) fsck.ext3: No such file or directory while trying to open /dev/c/c^M The superblock could not be read or does not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock: e2fsck -b 8193 <device> ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@ /dev/hdc2 none swap sw 0 0 /dev/hde2 none swap sw 0 0 /dev/hdg2 none swap sw 0 0 proc /proc proc defaults 0 0 /dev/c/c /c ext3 defaults,noatime,user_xattr,acl,user_xattr,user_ /dev/hdc1 / ext3 defaults,noatime 0 1and the nv+ that is up and running:
#----------------------------------------------------------------------------- # <device> <mount> <type> <options> <freq> <pass> #----------------------------------------------------------------------------- /dev/hdc1 / ext2 defaults,noatime 0 proc /proc proc defaults 0 0 /dev/hde2 swap swap defaults 0 0 /dev/hdc2 swap swap defaults 0 0 /dev/hdg2 swap swap defaults 0 0 /dev/c/c /c ext2 defaults,acl,user_xattr,usrqu
the one that is not running shows an ext3 filesystem, whereas the running one shows ext2. As far as i know i never changed this, but what i find more interesting is the long text before the fstab data starts. Even if i do not understand what it tries to tell me
ClausH42
Oct 09, 2015Aspirant
Hello,
i tried the df command and got a response, but this says nothing to me:
nas-1:/# df . -h
Filesystem Size Used Avail Use% Mounted on
- 1.9G 1.9G 66M 97% /
nas-1:/# df . -i
Filesystem Inodes IUsed IFree IUse% Mounted on
- 128000 14543 113457 12% /
I see that 97% is almost full, but the NAS has by far more diskspace. So i assume this is the room for the OS. Any idea how to correct this.
Oct 09, 2015Guru - Experienced User
ClausH42 wrote:
Hello,
nas-1:/# df . -h
nas-1:/# df . -i
The OS partition on the NV+ is only 2 GB. Normally it is around 20-25% full. 97% full certainly creates performance issues.
The next step is to find out where space is going. Look in /var/log and /var/cache first. It they are not the culprit, you'll need to poke around until you find them.
You can truncate run-away logs using "echo > filename"
You should be able to simply delete files in the cache, but don't delete folders. You can delete everything in /var/cache/minidlna/art_cache/c/ (including folders)
If you use DLNA, then there is an add-on to shift its cache to the "c" volume. If you want a link to that, let us know.
- ClausH42Oct 09, 2015Aspirant
I found besides other files:
total 335344 -rw-r--r-- 1 root root 329383 Okt 9 17:39 auth.log -rw-r--r-- 1 root root 13256492 Okt 9 15:57 kern.log -rw-r--r-- 1 root root 13386811 Okt 9 15:57 messages -rw-r--r-- 1 root root 40807755 Sep 25 20:38 mt-daapd.log -rw-r--r-- 1 root root 1130496 Sep 27 11:53 ReadyNAS_Remote.log -rw-r--r-- 1 root root 20817763 Okt 9 15:59 syslog -rw-r--r-- 1 root root 252985911 Sep 27 11:46 upnp-av.log
and in minidlna
-rw-r--r-- 1 root root 538775552 Sep 25 20:35 files.db
i will truncate them as you recommended and see what happens. Roughly calculated this is more than 1 GB already
Filesystem Size Used Avail Use% Mounted on - 1.9G 1019M 966M 52% /
Even though it seemed to be more than 1 GB i could only free up 966M
After reboot i still can only access the os partition. FSCK shows errors:
fsck 1.40.11 (17-June-2008) e2fsck 1.40.11 (17-June-2008) Warning! /dev/hdc1 is mounted. /dev/hdc1 contains a file system with errors, check forced. Pass 1: Checking inodes, blocks, and sizes Deleted inode 3002 has zero dtime. Fix? no Pass 2: Checking directory structure Pass 3: Checking directory connectivity Pass 4: Checking reference counts Pass 5: Checking group summary information Free blocks count wrong (61834, counted=61818). Fix? no Inode bitmap differences: -3002 Fix? no Free inodes count wrong (116672, counted=116659). Fix? no /dev/hdc1: ********** WARNING: Filesystem still has errors ********** /dev/hdc1: 11328/128000 files (1.2% non-contiguous), 66166/128000 blocks
i get a warning message that fsck might cause severe problems if it corrects the errors. I am not sure if i should run this next.
Raidar shows the NV+, Frontview does not work, Windows Explorer shows the NV+ too but it is not possible to access any folder.
What can i try next?
- StephenBOct 09, 2015Guru - Experienced User
I would reboot next, and probably pass on the fsck repair. You should have enough space to restore services.
It is a bit scary to have a corrupt root FS. If you get back CIFS access you should back things up. Then you can try the fsck, and if it goes wrong you can do a reset.
- ClausH42Oct 10, 2015Aspirant
So i rebooted result was the same "Booting done" but only accessible via Putty.
I switched the discs between my 2 NV+ v1. The discs from the nas that still worked are performing a FS check in the new position. The discs from the failed nas are still not accessible. The System says again "booting done" and nothing can be accessed as the raid (X-Raid) is not mounted. I searched the forum but i could not find a howto for mounting the shares from ssh.
Can you please describe what i have to do in putty to mount the shares? I would have enough space to transfer the data to my Ultra6 and then do a factory reset. Did i mention that pulling disc by disc (remaining 3 discs in position) did not lead to a system that booted.
Please tell me howto mount the shares if this is possible. I can restore data from different backups, but i invested a hell of time in sorting and tagging music and pictures.
