coulston
Mar 18, 2014Aspirant
ReadyNAS NV+ Unresponsive
My ReadyNAS NV+ has recently become unresponsive and no longer allows connections to Frontview or any of the shares. I am at a loss for what to try next, and I'm wondering if it is possible to save my...
Mar 20, 2014Guru - Experienced User
The OS is installed on the disks, so you have to leave them in.
coulston wrote: Do you think I should remove the drives before doing the OS reinstall to prevent data loss, or leave them plugged in?
