coulston
Mar 18, 2014Aspirant
ReadyNAS NV+ Unresponsive
My ReadyNAS NV+ has recently become unresponsive and no longer allows connections to Frontview or any of the shares. I am at a loss for what to try next, and I'm wondering if it is possible to save my...
vandermerwe
Mar 23, 2014Master
Power down, remove each disk in turn and check it using vendor tools. Replace before turning nas on.
If you verify that all of the disks are perfect, you should also do a memory test.
Do you have a a backup?
As StephenB has mentioned, a full OS partition is a possibility but will need someone to access the unit in tech support mode.
