MDS1968
Dec 31, 2014Aspirant
ReadyNAS NV+ v1 (Silver) and 3TB HDD
I have been reading some comments posted in this forum which appear to be misleading regarding 3Tb Hard drive compatibility with respect to the older ReadyNAS NV+ (silver) units. FOR THE RECORD, I...
Dec 31, 2014Guru - Experienced User
Found it! viewtopic.php?f=7&t=77990
StephenB wrote: I think I recall one poster who had installed 3 TB drives. His system functioned, but he didn't really know volume size. I'm not sure when this was, and its a bit hard to search for it even if you use google. If I find it I'll post a link.
The system functioned until a drive failed, and he apparently never looked at the capacity. It was pretty evident that he wasn't using the entire drive (since linux reader couldn't mount it).
