smithy50
Aug 01, 2012Tutor
ReadyNAS NV+ V2 - APC UPS SMT750I
I have a small home network that includes a ReadyNAS NV+ V2 and wish to add a 750VA UPS. The UPS model that I am considering is the APC Smart-UPS 750VA LCD 230V model# SMT750I The APC Smart UPS 750...
smithy50
Aug 01, 2012Tutor
mdgm, Thanks for the response. I also thought that the SMT750I would be compatible because of USB facility.
However, I was less confident when I got the following reply from ReadyNAS Support in response to my question asking if the SMT750I was compatible with the NV+ V2:-
If it is a USB UPS then the only way I would know is to test it. If it is a IP UPS then there should be no issue.
