smithy50
Aug 01, 2012Tutor
ReadyNAS NV+ V2 - APC UPS SMT750I
I have a small home network that includes a ReadyNAS NV+ V2 and wish to add a 750VA UPS. The UPS model that I am considering is the APC Smart-UPS 750VA LCD 230V model# SMT750I The APC Smart UPS 750...
smithy50
Sep 10, 2012Tutor
I decided to get the APC SMT750I UPS and test it with my ReadyNAS NV+ V2 running RAIDiator 5.3.5.
First, I did a safe power down of the ReadyNAS and connected its power lead to one of the power sockets on the UPS. I then connected the USB port on the SMT750I to one of the rear USB ports on the ReadyNAS using the USB lead supplied with the UPS.
I started the UPS and then started the ReadyNAS. During the ReadyNAS initialisation it displayed 'UPS Connected' on the front panel just before displaying the available and installed hard disk capacities.
Once the NAS was fully initialised, I opened the configure page in the ReadyNAS Dashboard and it showed the UPS icon as green and hovering over it with the mouse, displayed a dialogue balloon with the UPS Model shown as 'APC Smart-UPS 750', together with the the battery charge and estimated run-time.
I disconnected the mains supply to the UPS and its front panel indicators changed to reflect it going from mains supply to battery.
42 seconds after disconnecting the main ower supply from the UPS, a warning dialogue box popped up in the ReadyNAS window advising 'UPS is on battery'. The ReadyNAS also sent an email advising 'UPS is on battery power'
I continued to monitor the ReadyNAS configure page and it showed both the battery charge and run-time decreasing with time.
Eventually, a warning dialogue box popped up in the ReadyNAS configure page advising 'UPS battery is low, system will shutdown soon'. At this point the battery charge was shown as 10% and the run-time was 4 minutes. The ReadyNAS also sent an email advising 'UPS battery is low, system will shutdown soon'.
After a few seconds, a warning dialogue box popped up in the ReadyNAS Dashboard window advising 'UPS is shutting down system' and the ReadyNAS started to automatically shutdown. The ReadyNAS also sent an email advising 'UPS is shutting down system''.
The ReadyNAS safely shutdown.
I don't know what else, if anything, would be considered as a 'compatibility' issue. However, based on the above simple test, I think the ReadyNAS NV+ V2 and SMT750I appear to be compatible.
