BlokeUK
Oct 01, 2012Aspirant
ReadyNas NV+ V2 4 bay questions
Hello :D I am looking to purchase either the ReadyNas NV+ V2 4 bay or the Synology Ds413(j) in the next few days, but I would appreciate some clarification before I make a final decision. I ha...
BlokeUK
Thanks for the reply, do you know which HDD's Netgear use for their figures of: -
Power Consumption
52W typical with 4 x 2TB disks
48W idle, 22W with disk spin-down
If they are using drives similat to the 7k3000 thats would put the two pretty much on par for power consumption
Power Consumption
