digicammad
Oct 25, 2014Aspirant
ReadyNAS NV+ v2 and Samsung D3
Hi
I've just bought a 4tb Samsung D3 to backup my NAS. It is USB2/3 and works perfectly with my USB2 laptop but I can't get the ReadyNAS to recognise it.
I don't really want to have to backup via my laptop so can anybody offer suggestions as to how I can get it to work directly with the ReadyNAS?
Thanks
Ian
Thanks
Ian
- mdgm-ntgrNETGEAR Employee RetiredWhat version of RAIDiator are you running?
- digicammadAspirantThe latest - 5.3.11. The NAS recognises that a disk is connected but when I try to backup I get the following error:
Job: Full to USB
Protocol: local
Source: [c]/
Destination: [USB Device (Rear Top Port)]/
Backup failed. Sat Oct 25 12:50:07 GMT 2014.
Reason for failure:
The backup destination is a non-existent local share. - mdgm-ntgrNETGEAR Employee RetiredCan you write files to the disk mounting the network share for the USB drive on your PC?
If not, does it work with the other rear port?
Does it work with the front port? - digicammadAspirantAha, it seems to be working in the front port. I hadn't realised there was any difference between front and rear capabilities. If it works in the front is it likely to work in the bottom rear?
Thanks
Ian - mdgm-ntgrNETGEAR Employee RetiredThe rear ports are USB3 and the front is USB2.
It sounds like your USB drive may be incompatible with the USB3 ports on the NV+ v2. - StephenBGuru - Experienced User
Which is why the NAS (and many pc's) have both USB-2 and USB-3 ports.mdgm wrote: ...It sounds like your USB drive may be incompatible with the USB3 ports on the NV+ v2.
